RCU Forums - View Single Post - Angel S EVO Build Thread
Old 10-17-2008 | 05:05 PM
  #324
2Sunny
Default RE: Angel S EVO Build Thread
Got a response from Fedon:
Subject: Re: Proper wing versus stabilizer incidence on an Angel 50.
Date: October 17, 2008 8:03:27 AM EDT
To: joepeck66@ ******
Hi Joe
0.5 is ok 0.8 is out standard.
Please test the two wings incidence and make the zero on the canopy side.
You need test the fly reverse for see the line.
Send me ,please the results.
Regards
Luigi
Hi Joe
Regards
Luigi
So I'll check against the canopy line, and make some adjustments with the help of my buddy UAL767 then let everyone know how it goes.
In other news . . . I flew two new 5s5000TP batteries on the A50-12s with a 16x8 APCe. This was soooo much better than the 4s, because the 4s could only get to a CG of about 155mm and weighed in at a low wing load weight of 4.75 lbs. On 5s the CG was at 140mm and weighed 6lbs so she tracked much better even in slightly gusty conditions today. Below is a graph of the Hacker A50-12s with an APCe 16x8 on a TP 5s5000mAh battery:
