RCU Forums - View Single Post - Global freestyle elevator pushrod
Old 05-26-2003 | 08:52 PM
DownSideUp's Avatar
DownSideUp
Default Global freestyle elevator pushrod
I just flew my freestyle for the first time today. When pulling out of a loop at about 3/4 throttle (w/os .46fx) the plane took a wild turn one way until speed was slow and the flew straight again. This plane is set up with a pull-pull system on the rudder. The elevator is in two separate pieces controlled by one pushrod that is split at the tail and each end joins onto the horn on each side of the elevator. I am obviously coming up against too much pressure against the elevator when it is pulled up, but I don't hear anyone here talk about changing anything on their freestyles. I guess what I'm asking is could there be something I could check first before pulling out the pushrod and installing a pull-pull system in the elevator? Anyone with comments would be appreciated. Thank you.
