RE: Porting tips?
Porting weedies is fun.
General rule of thumb on carbs:
Bigger carbs require you to run higher RPM's. Get a smaller prop or lower pitch.
Smaller carbs will flow the right fuel/air mixes at lower RPM's if you want to lug down with a big prop.
When the carb gets too big, it won't transition past 1/3 or 1/2 throttle no matter how much you crank the needles down.
Exhaust:
About 150* duration - MAX
Shave the insides of your case gaskets. It does no good to port match the cylinder and the case if your gasket is 1/4" into the crankcase. That will mess up your flow no matter how much you port it. I glue the gasket to the case and let it dry overnight. Then use a SHARP exacto knife to trim out all the excess gasket on the inside of the case. Shave the carb and intake gaskets too. Glue the gasket to the carb insulator block or the cylinder. Let it dry overnight and trim any excess out of the fuel/air stream with an exacto knife.
Get a Bowman ring for it. Frank Bowman lives in Farmington, New Mexico and he has thousands of rings. If he doesn't have your ring, send the engine to him and he'll make one.
Electronic ignition is up to you. I like it and won't run a gasser without it. Some guys do fine with magneto ignition.
