RCU Forums - View Single Post - Midwest Citabria - Build Thread
Old 10-18-2008 | 01:16 AM
  #69
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Midwest Citabria - Build Thread
Got the aileron servos dialed in. I measured the servo arms beforehand. The JR4721 servos have a tiny screw in the top of the pot. If you remove the servo horn screw and put a tiny flathead screwdriver down the hole, there is a tiny screw that can be adjusted to re-center the pots. This keeps me from having to use sub-trims when I do the setup with the radio. I know it's a programmable radio and I know how to program it. [8D] I'd rather do it mechanically if there is a way.
Set the servos arms equal distances from the hinge line. Select the correct length H9 Pro-Links. Line up the controls horns and drill.
Turn the sound down if you don't like AeroSmith. I didn't realize my pocket camera had sound. [X(]
http://s198.photobucket.com/albums/a...rrent=1715.flv
