RCU Forums - View Single Post - Fly Eagle F-15 (1/9) Building Thread
Old 10-18-2008 | 01:26 AM
  #254
757Driver's Avatar
757Driver
My Feedback: (90)
Default RE: Fly Eagle F-15 (1/9) Building Thread
GSR, find a scale, LOL. Mine is 170mm with gear down and I thought it was very nose heavy. I'm going much further aft, atleast another 20mm as I said earlier.
NT, thanks. My servo boxes were glued together and were floating around loose in the wings. I'm going to use this setup. http://www.dreamworksrc.com/catalog/...products_id=57
The FEJ throws for the stabilator, ailerons were good and felt very comfortable at -40% expo. I have a dual rate on my rudder so that only minimal steering and rudder throws are active from TO to LDG. Flaps were great as well and as the RCJI article mentioned there is very little pitch change. The pitch change that did occur was only slightly nose down and I expect this to be minimized by moving the CG aft.
Ok DR D, clue me in, what exactly is seam tape? Where do you get it?
Peter, your build is comming along nicely. Does the single festo on your air system plate service both tanks? If so, do you have check valves installed to prevent one system leak contaminating the other? I like your setup. I love the 12FG and have already been planning on a radio system upgrade. Futaba ofcourse! That will most likely be a purchase for next year.
