RE: pull pull rudder setup
The rear bellcrank has the offset on the ends. These wires are crossed. The entire servo tray is mounted 1/8" higher on the right side. This prevents the cables from rubbing as they cross. The horns on the rudder are even with the hinge line. No slack on either side at any throw or deflection. Even tension.
Got lucky. [sm=tongue_smile.gif]
I want to try one of those SWB floating trays. [8D]
