RCU Forums - View Single Post - Fly Eagle F-15 (1/9) Building Thread
Old 10-18-2008 | 04:05 AM
  #257
Peter Brinkmann
Default RE: Fly Eagle F-15 (1/9) Building Thread
Hi Jason,
ORIGINAL: 757Driver
Peter, your build is comming along nicely. Does the single festo on your air system plate service both tanks? If so, do you have check valves installed to prevent one system leak contaminating the other? I like your setup. I love the 12FG and have already been planning on a radio system upgrade. Futaba ofcourse! That will most likely be a purchase for next year.
I use a barbed Y-connector after the Festovalve .. and use 2 further valves after the Y-connector... the festo one is a self closed valve vom Festo. It will bne close when you disconnect the tube.... from this.
I have a airsystgem for the retrakt an a 2nd airsystem for the brakes and geardoors ... i programmed the geardoorsequence with the T12fg TX... latest update (EU 1.6)
If you have a look to the picture you can see a Push-in Y-connector from festo ... i replace all the festo Push-in Y-connector where it is not usualy to use this because there are to expensive to use for nothing
