RE: I converted a glow engine to run on E85
Here in Brazil, the E85 is 85% ethanol / 15% water. the water acts as additive, raising and keeping heat of combustion. I think that little engines doesn´t like that water at all.
If your engines are runnig good, the answer is the gas in your E85.
And there is another problem, our gasoline have 23% of E85.
I will do some try with ethanol at 98% and castor oil.
good flying out there.
