RCU Forums - View Single Post - pull pull rudder setup
Old 10-18-2008 | 07:23 AM
coralcape
Default RE: pull pull rudder setup
So we're saying I can make up for the offset on the rudder servo by using offset servo arms? Interesting, I would never had thought of that. I was thinking instead of making up rudder horns that would allow the point of connection to be in line perpendicular to the hinge. My problem with that was the end of the horn would contact the fuselage, before full throw. I'm a DIYer and tend to make what I need. I can see a new servo horn in the future ) Thanks again folks, red
PS, I assume that I would offset the servo arm the same distance as the rudder horn, correct?
