RCU Forums - View Single Post - Help!! Help!! Need A Little Help Here
Old 05-27-2003 | 10:45 PM
Azcat59
Default Help!! Help!! Need A Little Help Here
It's an air bleed carb. I have had engines with these carbs and you could throw the screw away and it would idle ok, or maybe slightly rich even then. Good advice in an earlier response about drilling the air bleed hole slightly larger if the engine is still rich on idle with the screw backed totally out.
Clair
