RCU Forums - View Single Post - Tight diffs (problem when going around)
Old 10-19-2008 | 10:02 AM
Technex's Avatar
Technex
Default RE: Tight diffs (problem when going around)
ORIGINAL: Dawman
Oh , some reason I thought you put new gears in . But if you tightened the screws more then snug then probably it .
I did put new internal gears in (not external). Seems strange that it's worked fine on the rear ones.
Also the centre diff and rear today is smooth all throughout, just the front one.
Thanks everyone .
