RCU Forums - View Single Post - trex 450 se I need help with a few problems
Old 10-19-2008 | 10:15 AM
BryFlyGuy67's Avatar
BryFlyGuy67
Default RE: trex 450 se I need help with a few problems
A 4S pack on a stock TREX 450 V2 with an 11T pinion should net you ~ 3400 RPM.
How do you know your HS is 1600?
What motor are you using? If you are wanting to run 4S, you should get a motor that was designed for it (lower kV rating). In addition, with 4S, you need to be running a separate BEC or purchase an ESC that can handle the additional voltage.
There is a lot of tweaking and configuration involved with converting to a 4S setup.
As to your high frequency vibration, where are you seeing it?
