ORIGINAL: Gbaby158
Na, its a thing that happens on them carbs i've been told, the slide expands at a different rate. Look in the monster turck thread and then into HPI and picco engines.
Ok but you still have to change your linkage man unless im not seeing something in that picture. If you dont have that spring on the carb linkage to relieve pressure then when you aply brakes its trying to push the carb closed
