RCU Forums - View Single Post - spinner and prop keep flying off
Old 10-19-2008 | 11:32 AM
carrellh's Avatar
carrellh
Default RE: spinner and prop keep flying off
Look at the picture on page 12, step 4, of the manual. You should have visible clearance around the prop blades when everything is lined up correctly. Do not be afraid to trim the spinner with an exacto or grind on it with a dremel. Keep both slots as close to the same size as possible but do not drive yourself crazy over it.
