RE: CX2 Main gear misalignment problems
Chris
I have some extra CX2 parts so I made a mock up for you of what the gears should like and what parets go where, to the eye. The only thing missing is the last piece which is the collar at the bottom. However in my flying CX2 you will see the collar and the mesh alignment of the gears. You may have forgotton or lost the bearing that goes up in the bottom of the chassis, that and the thrust washer in my picture make that spacing from the gears to the chassis. Hope this helps!
JPee
