RCU Forums - View Single Post - OS .61 FX
Thread: OS .61 FX
Old 10-19-2002 | 06:08 PM
FHHuber
Banned
Default OS .61 FX
Check that the carb is firmly seated, and no air leaking under it.
Check for pinched fuel lines,
Check that the muffler pressure line is connected to the muffer at a wide section, not in the narrow acceleration tube.
(smoke system can go in the narrow part... It can draw a VACUUM in that portion of the pipe! The engine won't run above idle on tuned pipe if the pressure line is in the wrong place.)
Check for dirt/debris in the main nedle. You can choke fuel past the debris and still be unable to draw adequate fuel for the engine to run right.
