Diff Grease VS Diff Fluid. Doesn't the fluid leak out?
I've read a bunch about fluid vs grease and the handling differences, but nothing about reliability differences. Does fluid make the gears wear any better? Are you just putting fluid in the differential? or is it in the diff case where the ring and pinion are? Let me know I'm curious to give it a try.
Kevin
