RCU Forums - View Single Post - Diff Grease VS Diff Fluid. Doesn't the fluid leak out?
Old 10-20-2008 | 02:08 AM
black mamba's Avatar
black mamba
Default RE: Diff Grease VS Diff Fluid. Doesn't the fluid leak out?
The grease goes on the ring and pinion gears, which are the outer gears. The silicone goes in the diff case itself, submerging the spider and side gears within it. The silicone shouldn't leak out because the diff case is sealed with orings and a gasket.
