New DA100 or BME105?
Straight from Cheif aircraft
3W-106B2 Classic 106cc Twin
Part No. 3W 106B2
Horsepower 9.3 HP
Bore 1.73 in
Stroke 1.26 in
Speed Range 1200-8500 rpm
Oil Mix 1:50-1:80 Mix
Ignition 4.8V
Weight 5.9 lbs
Crankshaft 3 Ball Bearings
Length 7.5 in
Width 11.4 in
Muffler No
CART ADD
Price $1095.00
DA 100 Engine 100cc ADD $1150.00
DA-100 Specifications: Displacement: 6.1 ci. (100cc)
Output: 9.8 hp
Recommended Props:
2-blade: 26x12, 27x10, 28x10.
3-blade: 24x12, 25x12, 26x12.
Weight: 5.8 lbs (2.63 kilos)
Length: 6.5" (162.5mm)
Width: 11.45" (290.8mm) (w/ plug caps)
Bore: 1.6771" (42.6mm)
Stroke: 1.3779" (35mm)
Typical RPM: 1,000 to 6,700
8,500 max RPM
Fuel Draw: 2.5 oz/min at 6,000 RPM.
Three crank bearings
Four petal reed valve, bottom induction.
Desert Aircraft auto advance electronic ignition.
Walbro Carb.
Exclusive Desert Aircraft designed cylinders, pistons and crankshaft.
Three-piece CNC milled, 2024 T3 aluminum alloy crankcase.
Low vibration.
Most torque in its class .
Long rod to stroke ratio.
Aerobatic power curve.
Two-year warranty.
