RE: OS46FX - Throttle Stop Screw - what does it do?
The best thing to do with the throttle stop screw is to make sure it doesn't interfere with the carb barrel closing all the way and then leave it alone. If the servo linkage and transmitter end points are set up correctly it will not bind.
