RE: To Fiberglass or not to Fiberglass?
Glassing takes A lot more time then covering but on some planes it is just the only way to go. This year I was talked into glassing using the method taught at Completely Scale RC. It took A bit longer but I did A few different things that I was told to try. I used 1/2 oz glass too. What an outstanding finish!! So much smoother then epoxy and as light as covering. I will be using thiws method from now on, longer but better.
