RCU Forums - View Single Post - Fuel Consumption
Old 10-21-2008 | 11:36 AM
Truckracer
My Feedback: (19)
Default RE: Fuel Consumption
ORIGINAL: arobatx
I agree with the capt... folks might plan to carry X ounces of fuel on board, based on an ounce per minute quote at full throttle, assuming the highest possible draw, with given prop...etc. However, if you are like me, I only like to carry what I need, and not much if any more. I see no point in carrying the extra weight in the planes I fly.
Since you are looking to run smoke, I completely understand your need to figure out what you must carry, vs what would simply work, so you can fit the tanks in place without fussing later.
I went this route, with a WOT quote, given prop, on a ZDZ80, and tanked my plane accordingly. I flew the snot out of it, several flights, exactly how I fly, not WOT the entire flight, of course....and I found after many flights, I would consistently use only a little more than 1/3 the recommended tank size for a 10-12 minute flight. I then went back in and retrofit a more appropriately sized tank for my application.
Perhaps before going with smoke, go with what the capt suggests. Put in a rough guess on tank size...fly and measure. Then permanently mount what you will know work for your application and flying style.
Good reply chad .... exact fuel consumption will vary depending on an indiciduals flying style, plane weight, plane type, etc. I know on a heavy warbird my fuel consumption would be considerable more than with the same engine mounted on a light weight aerobatic plane.
