RE: O.S. 120 in a Venus II
BlackS10
I imagine you're probably running a OS #8 plug, but in case you're not, that is the plug to use. I've seen several try to use other type plugs in smaller 2 stoke engines and get the same results you are stating. Also, a OS F will work good too.
Todd
