RE: To Fiberglass or not to Fiberglass?
If you are using the epoxy for finishing, don't thin it with ANYTHING. Use as is, or heat it up a little to let it flow better. Heating will speed the cure time.
Thinning with chemicals will result in a never cured situation, maiking a real mess for finishing.
