RCU Forums - View Single Post - FUNJET
Thread: FUNJET
Old 10-21-2008 | 01:31 PM
  #301
chippedprop
Default RE: FUNJET
I looked up your motor. Main issue is wght. 7.2 oz. If it's all you have then OK. If you can buy another, I like HET (Mega clones) get the EDF 2W-25 rated for up to 6 cells wght. 3.8 oz vs 7.2 oz............. higher kv = faster prop speed. Copy of the mega 16/25/2 I have one and I Know what it will do.
Lighter weight in a FunJet equals more FUN.
a quick motor calc on the smaller HET motor...
4 cell
APC 5.5x4.5 prop
Prop speed 140 +
est ground speed 120 +/-
Amps in the 50-55 range WOT
That's pretty quick !!!
5 and 6 cell is......... well just crazy fast!!!!!!!! Plus you'll have to get a 80 to 100 amp ESC ..........3200 plus ma battery........couple of pairs of clean under wear etc.
I guessing your turning 7 to 8 props on your current motor due to low kv ???
Oh Make sure you add Carbon fiber tubes nose to tail and wing tip to tip. A must with that monster size motor on it's butt.
CP
