RCU Forums - View Single Post - spinner and prop keep flying off
Old 10-21-2008 | 01:58 PM
flyX
Default RE: spinner and prop keep flying off
On new 2 stroke engines it happens more. The cylinder on 2 strokes non-rings nitro engines are tappered.
Sometimes you'll flood the engine a little bit..cuasing almost a freeze lock.
So when you press the electric starter's cone againts the spinner, it'll loosen the spinner and prop a little bit at a time.
As stew stated...don't have the engine at TDC when using an electric starter.
if you're going to use Loctite...DO NOT USE RED.[X(]
Use Blue.....
