RE: BVM Agressor II Build Thread
Well, after a 6 month hiatus (had do do that flying thing all summer), the weather here in North East Ohio has started to turn to $#%$. Flying will be few and far between.
I started back on the Aggressor.
Here are a few pics of some of the progress.
All the surfaces have been completed and fiberglassed. They are ready for a final sand then primer. The last pic shows a neat little modification. I cut the back of the fuse off and installed an old BVM Bandit tail cone. Alittle lite bondo filler and it will flow to the contour of the fuse. See save those wrecked parts, you never know where you can use them.
Maybe a few suggestions here, I am sstuck as to wheather to cut a front hatch just forward of the canopy or cut the nose off and make it removable to install the gear and brake servos and valve and the RX and Batt.
Give me some suggestions.
Joe L.
