RE: Fuel Consumption
You can always install a tank larger than necessary and measure the flight time against fuel use. Then you can adjust the fill by lowering the vent tube.
Also tanks are inexpensive and you can easily change the tank size later if desired.
I would start with a 12 to 16 oz tank.
Bill
