ORIGINAL: Gray Beard
Klass Kote is A bit different but if you happen to have some K&B part A most the time you can get away with using Klass Kote part B and it works. KK is just like the old K&B in use and just as tough. I don't use the water based poly U, I use the Deft Brushing Laquer but due to the smell and effects to my brain when using it I plan on giving the water based A try next time. This Extra 260 was done using the method from Completely Scale RC then I used Klass Kote two part for color with silver dope for the stripes. So smooth, so light, so strong!!!! Took A lot of time!![&o]
Is that a kit? What size? Where did you get it?
