Seagull edge 540 .46 size CG?
I just got my seagull edge 540 done with a saito .82. I have standard futaba servos an alum spinner and hydrimax five cell 2/3 battery, which the battery hasnt been mounted yet because of the fact the plane is extrmly nose heavy. I even set the battery on the tail and still couldn't get it to balance at the recommended cg of 9.5cm from leading edge at the tip. I called Horizon and the said that was the correct cg point. Any body else have the same plane setup that has flown it are they right or can someone give me some advice?
