RE: Scaled Tiporare Plans
Don,
if you're inclined to keeping to the built up approach, it would considerably ease the work of building to have the triangular sections laser cut as part of the short kit. As I mentioned above, the only change that I think is called for is a thicker sub fin tip section (1/4" stock) as well as another piece of 1/4" in the fin at the rudder's mid rib to provide hinge point material. This would reduce the triangular sections count to bottom, front and the 4 internal.
It would be great to see your CAD efforts once you have something you like.
I'll get back to you re the plans later today.
David.
