RCU Forums - View Single Post - skink
Thread: skink
Old 10-22-2008 | 03:59 PM
bubbajoexx's Avatar
bubbajoexx
Default RE: skink
started to build the machine gun 20mm rollers to insert into the turret they will be full up down movement and synked in and out as fired
these brass rollers will be shafted together and mounted into a rottor block attached to the turret base as well as drilled and barrel slides installed ito each one then I will cut the barrels to fit into the slides
ID:	1057049   Click image for larger version
