RCU Forums - View Single Post - I converted a glow engine to run on E85
Old 10-22-2008 | 09:07 PM
  #103
captinjohn
Default RE: I converted a glow engine to run on E85
ORIGINAL: gkamysz
I guess nobody has determined the optimum E85 fuel mix. It sounds like it's time to experiment. I'll be doing so soon.
I think this E85 thing is still in the first stages. Looks like more has to be verified??? Be sure and read how metals can be eaten away from the use of E85 and similar fuels. I would use after run oil and while engine is still running...hook up a small tank to carb and purge out the carb with fuel you know is ok on engines and cards. Capt,n
