RCU Forums - View Single Post - servos, attaching prop to engine
Old 10-22-2008 | 09:56 PM
500 lb. koolaid man's Avatar
500 lb. koolaid man
Default RE: servos, attaching prop to engine
Info on a prop size for a chainsaw might be hard to find. Not many people use chainsaw motors. Due to all the torque and HP of them though, I'd recommend a prop on the larger size used for a weed wacker motor. Sorry I can't give you any specifics.
Since it's a gasser, it's recomended that you get a high torque servo for the rudders.
A suggestion for the rudders http://www3.towerhobbies.com/cgi-bin...&I=LXDTB3&P=ML
And a Futaba S3003 or S3004 or equivalent will work fine for the throttle. Any servo will work fine for it really.
