RE: Official E-Maxx Thread
I charge my 4800 mah lipos at 4 amps. They are supposed to be charged at 1C rate. I am pretty sure on 4800mah lipos that would be 4.8 amps.
I don't get why the EVX2 is not LiPo compatible. DC Voltage is DC Voltage. Sure the LiPo will have less resistance than most NIMH batteries but that only means it will have a higher amp output. So if the EVX2 will run 14 cells at 16.8V then it should handle the 14.8V of two Lipos.
