RE: CMP BF109F BUILDING THREAD
HR Todd
I agree with you.
The elevator is just one of the indicators one can use. The more you know about the airframes construction, the more you know what your models info/behavior upon your first flight means.
Arfs being pre fab models opens up many variables. If one doesn't check/know things like all incidence, engine angle, and stuff like that, the elevator info could be misleading or useless or even create more confusion to the modeler.
In this 109 at 71-72" span @around 13-14lbs, I believe it should be pretty forgiving to the seasoned semi scale warbird modeler.
I have managed to pick up 2 full sets of spare parts minus only the fuses. I will probably throw a CMP factory wing together real quick, just for the sake of seeing if its a model I want to keep indefinitely.
Steve
