RCU Forums - View Single Post - which G4 plane to start with
Old 10-23-2008 | 01:54 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: which G4 plane to start with
If you plan on using the simulator to ASSIST in learning to fly then you should do it in conjunction with an instructor. You should be flying a plane on the simulator that is as close to your real life trainer as possible. In addition, you should use the simulator to practice and reenforce what you learn each lesson with your instructor. Too many people try to teach themselves to fly using a simulator only to lengthen their real training time because they will pick up bad habits on the simulator.
Here's a list of some of the "bad" habits one can develop:
1) Failing to keep the plane straight during takeoff run.
2) Climbing out too steep.
3) Not maintaining a constant altitude while turning.
4) Turns that aren't smooth, too sharp, etc.
5) Forgetting that there is a left stick.
6) Not lining up with the runway during landing approach.
7) Using ailerons instead of rudder to make course corrections when landing.
8) Using the elevator to extend the landing when you realize you're short.
9) Failure to learn the signs that a plane is about to stall, and what to do to avoid it, or recover from it.
The sim is NOT:
[ul][*]Going to teach you how to tune your engine [*]Going to teach you how to correct fuel system problems [*]Going to teach you how to set up your linkages [*]Going to show you about lateral inbalance and surface warp [*]Going to locate errors in assembly [*]Going to teach you how to maiden a plane [*]Going to trim out your plane [*]Going to simulate other flyers at the field [*]Going to blow a hard gust of air at your plane at just the wrong time [*]Going to simulate that hard sink thermal just off the runway threshold, though doable in G4 [*]Going to have a bird come out and attack your plane in the air [*]Going to give you the weak knees you'll get the first time you fly [*]Going to throw a bug in your face and the sun glare in your eyes at the wrong time
[/ul]
Ken
