John,
I hate to disagree with you, but you almost always need some sort of throttle rudder mix to compensate for torque. If you put right thrust in you will need some on the downlines. If you go back and read some of Chip's trimming method's he can explain it a lot better than I can. Some people mix rudder to idle. I personally mix a little rudder with the addition of power, simply because I like my rudder neutral at idle. I had a VERY long discussion with Chip in Iraq over this very point (was amazing to have a guy who has seen and done as much as Chip being able to answer any question I had for 2 months). I actually had read his notes previously and had taken his advice, and loved how the plane felt. One problem is with todays designs running much larger props, you can't put enough right thrust in to totally fix the problems. Dave Guerin suggested when I talked to him a couple of years ago in Phoenix on some electrics you would need 5+ degrees of right thrust to totally compensate for the torque factor. This would cause the plane to yaw horrible when flying straight and level, so the compromise is mixing some rudder to throttle.
Arch
Here is the link to Chip's comments. This is a MUCH shorter version, but you get the idea.
http://www.rcaerobats.net/trim_chart.htm
