RCU Forums - View Single Post - DW Yak - balancing question
Old 10-23-2008 | 08:52 PM
Xpress's Avatar
Xpress
Default RE: DW Yak - balancing question
I always put the CG 1/4" behind the spar. If you really want a locked in yak, then you need to run a setup that keeps the plane under 14.5-15oz.
With the CG on the spar, flight is neutral on all axis. Awesome flying.
