ORIGINAL: dithersail
So I understand that 10x6 is the way to go to get it screaming, want to order a long pipe and header. Does anyone know the right header and pipe to use (Macs I assume, maybe I need Dub to make a header) also the silicone adapter. This will be my first piped 2 stroke so any advice would be appreciated. (Bob?)
You know that's a tuned muffler on it now, right? Pretty good rpm boost already if you prop it correctly, but not quite as much as a pipe can provide.
Go to the Jett direct support forum under glow engines, and post your question there. But Bob Brassell also checks here too so may catch this pretty quick.
MJD
