RE: E85 Gas
Good Morning Capt,n,
I have run E85 in a number of engines besides my SuperTigre. (I mentioned that I had used it in the ST over in the other thread) It has not caused any unusual problems in any of them and certainly no corroding or sticking of parts. The carb has to be readjusted when you switch from standard gasoline blends but the carbs I have tried it on worked just fine. (Walbro and Zama) Pe mentioned water in the E85 and maybe that was his problem. (Icing up?)
