RE: Does This Look Right
Oh yeah, it looks like it might give the model some up and right thrust. Few midwing models need up thrust. But eyeballing from the side ought to give you some idea.
Stick a yardstick to the side aligned to the wing's centerline. That'll help show you the up/down thrust of the engine. Who knows, maybe the bulkhead that motor box is glued to is out of alignment the other direction. A yardstick masking taped to the underside of the fuselage along it's centerline should help show you the side thrust.
