ORIGINAL: Hibrass
Thanks TKG,
Does that use the standard size plug or can it use the short cm6 style??? Or is that not an option?
Whatever you NEED/WANT.... The ignition set up is same $$$, but you would need to buy spark plug and a 14mm to 10mm adapter. We got both.
