RCU Forums - View Single Post - S-90K Question... Backplates!
Old 10-25-2008 | 12:51 AM
xlr82v2's Avatar
xlr82v2
Default S-90K Question... Backplates!
Bax,
I just got a new to me low time S-90K, and the backplate on it has been tapped for crankcase pressure, presumably to run a pump. My installation will not require a pump, so I need a backplate that has not been tapped.
Will a backplate for a G90 fit the crankcase of the S-90K? I know they are different part numbers (I've been searching all night so far) but I can't find any info on this otherwise. If the only difference between the 2 part numbers is "CHINA" stamped on the back, I'm fine with that. The dimensions are what's important.
Your help will be greatly appreciated!!
