RCU Forums - View Single Post - Do 2-stroke engines run clockwise
Old 10-25-2008 | 03:04 AM
Ram Jet's Avatar
Ram Jet
Default RE: Do 2-stroke engines run clockwise
I don't think you can run any rotary valve (intake through the crank) backwards. A reed valve doesn't care, it will run in either direction. There are some Enyas you can rotate the front housing 90 degrees and run backwards with minimal affect on intake timing but I don't remember which model.
Bill
