RCU Forums - View Single Post - 7 UAP Super MIX error on power on
Old 05-27-2003 | 03:36 PM
Krysta
Default 7 UAP Super MIX error on power on
Hi besunta,
The Mix light will flash when snap roll, 6-2 mixing, idle up, throttle hold, inverted flight, or rudder offset is on. The warning alarm will sound when the airbrake, throttle hold, or idle up is ON when the power is turned on.
I would check each of these functions in their menus to see if this is the cause of your problem.
I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected].
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://.futaba
