Sharku
This is an excellent kit, as are all Great Planes"s kits. I built this plane about 14 years ago. The only thing I would change if I were building this kit today, would be to replace the single servo in the center of the wing, which connects to the ailerons with nyrods, with two servos, one for each aileron. In fact I intend to make this change on my Corsair this winter, as I find I was never happy that there was so much friction in the nyrods, which has caused the single servo to start to wobble under load. Otherwise I love this plane, although it is not a beginner plane if you are just starting out with airplanes. However if it takes you two years to build, you should be well qualified by then.
Lm
