RE: Return of Lunchbox..
full bearings yes.
i have found the problem and in true british style have fixed it without spending a penny on it!!
the counter gear had 2 teeth that were bured over so that when the pinion gear came to that part it couldnt mesh properly,
my remedy, file the 2 teeth back into shape(ish) and it all seems ok for now.
so LB fans my advice is this.. if you're going to go fast.. grease your gearbox frequently!!!!!
