RCU Forums - View Single Post - Micro Receiver
Old 10-25-2008 | 07:11 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Micro Receiver
Hitec crystals ARE avaliable for the full spectrum and are avaliable at more dealers than even Futaba if you dealer does not have your channel then find another its as simple as that. Agine do not use the Futaba crystal It may appear that it works to you however at that point you may have turned your radio into a dirty radio and your fellow flyers will not appreiciate that! You bought a quality product do not hinder its performance with an improper crystal.
By the way the high low thing does not apply to Hitec Rx's period any hitec Rx is plug and play across the band. That is an antiquated tuning method only recently abandoned by Futaba.
Agine you are overamping about range This Rx in my opinion is a superior performer than the Rx that likely originally came with your radio.
John
