RE: oderless CA is it safe?
The problem with CA is that different people react differently. You can look at the Material Safety Data Sheet, but it won't tell you how you'll react. The only way to be sure it to try it, but use caution. Plenty of ventilation, and even consider using an air filter mask with an organic vapor cartridge. If you experience any indication of allergic response (may take a number of hours to develop), quit using it.
Brad
